Bassmon wrote:
Hey guy's.
TV-2004 Dodge 2500 GVWR-9000, Payload-2020, Tow weight-9850,GCWR-17000. FW, Dry-8150, Pin-1115,
It looks to me that if I travel light I should be ok. Would this assessment be correct?
Thank's
Larry
No scale axle weight numbers ??
The Cummins or a the Hemi gas engine ??
Gear ratio ??
Manual or auto tranny ??
I have the same truck in '03 model. Its a quad cab short bed Dodge/Cummins 3.73 gear and NV5600 tranny .....a 6000 lb RAWR>.
With a 13350 lb tow rating.
This trucks rear axle weighs 2840 lb leaving it with a 3160 lb max payload in the bed.
My 5th wheel RV trailer weighs 11200-11400 depending on how its loaded. This trailers scaled pin weight varies from 2200 range-2400 lb range or around 20 percent.
Actual scaled rear axle weights run in the 5300-5500 lb range all depending on stuff we pack.
The '04 2500 Dodge/Cummins tow ratings for a 5th wheel/GN trailers start in the 12k range and up. Are you looking at bumper pull tow weights ??
