Jan-16-2017 12:44 PM
Jan-19-2017 06:34 PM
Jan-19-2017 04:11 PM
Jan-17-2017 07:42 PM
Jan-17-2017 06:10 PM
Searching_Ut wrote:
I have a backflip on my shortbed Ram, and so far haven't had any issues. I use it in the 3/4 folded position though not all the way up against the window. With a shortbed you want to be able to see the 5er when backing into a spot because if you turn sharp enough it will hit the cab even with cutouts. The underside of the trailer hasn't ever contacted the cover even in a sharp turn where I'm only a couple inches from the rear window. I do watch it close if I'm on really uneven terrain. I've used it with both and Andersen ultimate hitch, and more recently with a B&W companion.
Jan-17-2017 04:26 PM
Jan-17-2017 11:14 AM
Jan-17-2017 04:35 AM
Jan-17-2017 03:50 AM
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
Jan-17-2017 03:33 AM
FireRob wrote:
Reading all these posts and seeing the covers stacked near the cab with no issue and clearly above the bed rails. It has me wondering because when I asked about a fuel tank sticking above the rails an inch and a quarter the mass consensus was it had to be below the bed rails. Have to rethink my choice a little more.
Jan-16-2017 07:54 PM
Jan-16-2017 02:55 PM
Jan-16-2017 02:21 PM
Jan-16-2017 01:44 PM
Jan-16-2017 01:30 PM
