Atwood water heater won't shut off.
heavyodie1
Have a G10-3e that is heating to the point of pressure relief valve weeping. Water is extremely hot and the gas doesn't shut off. This is a gas only water heater and I have replaced the gas valve and the thermostats with no difference. Don't know what to try next.
9 REPLIES 9
heavyodie1
Had a hard time finding the 1/2" regulator but did get it replaced. Everything worked fine and water temp is 150 when it shuts off. Thanks everyone for the help.
WeBeFulltimers
heavyodie1 wrote:
You were right OB. I again tried the air pocket then lit the gas and let it go until the regulator started weeping. Checked the water temp and it was 155. I will replace the regulator next weekend and let you know if that fixes it. I am using an electric hot rod right now but our park frowns on using electric.??
I bet your park smiles when you pay the rent!
2012 Ford F-350 PSD SRW ** CURT Q24 ** 2018.5 MONTANA 3791RD
heavyodie1
heavyodie1
Thanks OB. I won't be at the trailer until this weekend so I'll get back to you.
Old-Biscuit
You stated ....."have replaced gas valve and the thermostats with no difference"
Then you did not get t-stats tight against water heater tank wall.
I do not like Atwoods method of holding t-stats. Plastic washer pressing against a spring that has to be held compressed by three small tabs.
If tank wall is dirty where t-stats touch......t-stats won't sense temp (actually temp will go higher before t-stat opens
If t-stats are not tight.... same ----high temp before opening
If t-stats terminals/connectors not clean & tight....t-stats can open erratic
Turn water heater ON
When propane shuts off OR T&P Weeping hot water (it steams when it is released into atmosphere----doubt it is 210*F-----hot but not that high)
Collect a cup of full hot from faucet with thermometer in cup.......note highest temp reaches.
With that info...........easier to pin point issue
Post here or PM me with temps.
larry_barnhart
I would guess the TT is not good or installed correct. The relief valve leaks because the water is hot and the reason for this relief valve. Air chamber as was posted above should help the problem. what else can the problem caused from?
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
heavyodie1
Old-Biscuit wrote:
You have a 10 gallon DSI propane water heater
It has 2 t-stats
Brown wire goes to normal t-stat (preset 140*F)
Red wire goes to ECO (high temp) t-stat (preset 180*F)
T&P Relief valve OPENS at 210*F/150 PSI
Weeping ......
Water swells when heated. If air pocket in top of tank (there by design) gets lost pressure can build up causing T&P to weep
Turn off water supply
Open faucet hot side to relieve pressure
Open T&P via lever....let snap close when water stops running out
Close faucet
Turn on water supply
Thanks. I've done all of that with no improvement. The water is steaming hot when the pressure relief starts weeping so I don't think there is a problem with that. Don't know what to try next.
darsben
Manual is here
http://bryantrv.com/docs2/docs/atwoodwaterheater.pdf
Traveling with my best friend my wife!
Old-Biscuit
It has 2 t-stats
Weeping ......
Close faucet
