best bet is to use welding cable. far less power drop.
but.... you must protect the cable. as the housing is very soft and can be cut way easyer than you can belive.
all conections, us gold plated items ( see the car stereo sites for these).
buy a better grade and larger than you think you will need power inverter. ( will last far longer, with no "problems").
and double the number of storage batteries ( four of them min . aka 12 volt).
i know sounds over kill, but one should never have a supplyed power drop this way.
is possable check and maybe replace the coach wiring as it may be sub-standard
(aka: cheap, wrong style/ kind of wire) as the manf do cut corners.
