Homey_B
May 01, 2015Explorer
Battery Switch and Brake breakaway protection
I've finally decided to install a battery cut-out switch in my Copper Canyon. It seems simple enough - put the switch between the battery and the junction block where the Positive lead is attached to the rest of the electrical system.
My concern comes from the emergency brake cutoff. I have read that you never want to cut the power from that system. It prevents you from driving off with the battery disconnected, leaving you with absolutely no emergency brake capability. Yes, I realize that if the breakaway switch trips, I have much bigger issues, especially with a 5th wheel!
So, let's just play this through. I have to figure out where the brake power comes from. There are four wires on the battery splice block. One is the battery. I presume another comes from the RV power distribution panel. The other two come from where I cannot say.
Or, let's work backwards from the breakaway switch. The two leads go into the RV through the same wire bundle that the tow cable follows. But once it gets into the base of the pinbox, it gets lost.
Are there any suggestions on how to locate this system so that I can wire it directly to the battery (and avoid the soon-to-be-installed disconnect switch)?
Any help you can offer would be greatly appreciated! Thanks in advance!
