Update on bed frame and continuing leak in bedroom slide. We found leaks after a heavy rain storm in the bedroom slide after the bed frame found to be loose. Took to dealer after discovering the floor was rotten around the edges of the bedroom slide. These leaks have been worked on by this dealer and a mobile repair person before. Dealer said should file an insurance claim as some companies have paid for similar problems. After about a month, claim denied. Dealer replaced the floor. I asked them to anchor the head of the bed frame to the wall studs, attach raised part of bed frame to slide floor and rebuild the bed frame. They took the slide out and found two wall studs in the wall where you would anchor the frame were not there. It came from the factory that way. These missing studs and the way the floor was installed caused excessive slide flex according to the dealer. This is probably some of the reasons we have had continuing problems with leaks and a loose bed frame. We will see after the next rain when the slides are out to see if we have more problems. Some of the carpet had to be replaced. Original cost was $4,200 and dealer deducted $1,100 from the bill. Dealer included tire rotation, and some other cosmetic repairs in the bill of $3,100.
2017 Montana 3611 RL
2012 Chevy 2500HD Duramax
