routemaster's avatar
routemaster
Bedroom slide bind
I have an issue with our bed slide with the Bal-Accu system installed. Problem is that the top left and bottom right corners are in a bind and have destroyed the wipes. On inspection, I have found that the sill is running down towards the front the king studs are plumb. So, I am thinking to take the box out of the bind I would have to shim up the rollers by at least 1/4"+ on the first one then a 1/8" on the second one, which I don't think is likely to do no space to get at the screws or I have some three-roller plates which I could shim too different thicknesses to create the run on the sill. One other thing that came to mind was to buy a J-36 roller and fix the outside wall. Thoughts, please.
Make sense?
