Frankandbeans wrote:
Wow...ok. So many options to choose from regarding what kind of fiberglass repair kit to use!
How about step 1 - What do you guys think of using the expanda foam as a way of having something for the fiber glass patch to stick to? I will take a picture of what I'm working with tonight so everyone can see what I'm trying to accomplish.
I AM going to fix this myself. I'm seeing a lot of similarities in RV's and sport bikes - it doesn't take much to total out these things. To be honest, it's not blue booking for a whole lot, and if I made an insurance claim to fix this and some other minor things (That aren't that big of a deal, but labor prices are insane), I'm willing to bet they could total it. I just want it to be water proof and as close to smooth as I can get it. I'll paint it with the classiest rattle can I can find, and call it good.
It's not that hard, I really don't care what anybody says. I've repaired mach3+ aircraft panels and they're still flying, or in a museum now hahaha.
I would say no on the expanding foam. Next, I would find out for sure what kind of resin was used to make the door. Next, there is a product for this kind of repair. It's like the above poster said, bondo type material, it's green and does have the fiber in it. It is the strongest I've found in 39 years. A good auto paint sore will have it, it's Evercoat Kitty Hair. Stronger than the Hulk (hahaha), really it is good.
Sand the door and surrounding area with some 36-60 grit to get ready. Mix up the kitty hair, and put it into the hole, as long as it's not a gapping hole that has no solids in it all the way around the hole. I mean there is enough material to keep the kitty hair from falling inside the door, and too deep. (kinda hard to tell with words and no pictures)
Be careful to not over fill, this kitty hair is a big bear to sand smooth. Fill it enough, but not over fill. Use an airfile to sand it down (auto body shop for about $100 or harbour freight for $50 maybe). For the last thin coat, regular body filler over 36-60 grit scratch marks will be ok, it'll stick.
Get it smooth, and spray some primer over the repair. Use a very flat board, plexiglass, t angle or any tool that is very flat and can put a piece of sand paper on it. If you do it by hand, you'll have all kinds of divets in it.
It should be smooth and ready to paint at this point.
BBTank
