valhalla360 wrote:
dsrace wrote:
i did buy a custom built trailer and it is only 30' oal. i thought for sure that was short enough on the bumper that it would tow close to as nice as the fiver we previously had run for 10 years. i guess i was spoiled with the fiver! empty it tows great but wind has grabbed it a couple times and i felt that behind my drw. i kept the drw as the f350 diesel is paid for and trucks are crazy high imo.
Have you taken it to the scales to see what your weights are?
If empty it pulls great and loaded it's squirrely, it may be that you are too light on the tongue when loaded.
A properly set up bumper pull will tow just fine. Not as good as a 5er but shouldn't be an issue.
How bad was the cross wind? I've had the wind grab us both with 5er and bumper pull. If it's strong enough, I've seen semis blown around.
you make a very good point and i have not weighed it. a series of events in 2022 kept me from using it more then once and that was a 9 hr drive, empty, to mt rushmore and back.
dune sport said they weighed it, stated it weighed 7195 lbs / 1195 lbs tongue, empty. i call that 7200/1200 lbs. i want to believe them but i do need to know for sure and i need to know loaded as well. there is a cat scale/truck stop, 25 miles from me as well. thinking about a weigh safe hitch to see the different tongue weights loaded differently once i weigh it loaded at the cat scale.
i pulled our then , 2011 wolf pack 295 34' fiver for 10 years. high winds would grab it but for the most part, never horrible. had a couple experiences between rawlings and rock springs wyoming that were attention getters....swirling wind. when i say high winds, i am referring to 30 to 40 mph gusting winds. a good trip is 15 to 20 mph winds around here, through kansas, wyoming, nebraska and now got to experience 30/35 mph gusting winds through part of south dakota. alot of it is the times of the year i can get away. the 9hr trip to mt rushmore, empty, wasn't bad at all. the worst of the tow in those gusting winds was through the hills. it got concerning but never out of control. picture below is at the camp ground by mt rushmore sd and other is at the sand dunes in oklahoma. in the pic of it at the heatland rv park in sd, that is w/o asssist from the anderson wdh anti sway system.
so, i have only made one trip loaded with the sand rail ( oct '21 ) as i have missed all dune trips for 2022. 1 trip empty to mt rushmore. between a massive hail storm ( $42k in damages to just our house), tree removal/clean up and finishing the build on this toyhauler ( luckily it was in the building ).
the only trip i've made loaded was in 25/35 mph gusting winds for 5 out of a 7 hr drive. yes i know those are higher winds and they will effect a bumper hitch more so then a fiver/GN and that is why i am looking at the bpconversion. during that 7hr dune trip drive, i had to stop 4 different times to adjust the anderson wdh. i finally set it too tight and that def makes it worse. north of salina kansas, i got hit, diagonally, twice, and i could read the side of the toyhauler in my mirror. i hit the the trailer brake to straighten it out as i let off until i got to an exit. that is when i started shifting weight to the nose. been many years since i felt wind throw a trailer and a drw around like that! moved the spare tires from the rear to the front and tool boxs as i listed above in my previous reply. that made an 85% change for the better and i continued. definitely tongue light with the sand rail pulled in. my fear is that shifting that weight permanently might make it tongue heavy empty??
its 2k lbs ( specifically 1960 lb wet ) and 60% of that is in the rear w/o occupants. backing it in is doable with the winch, but not a fun time. have to swap rear tires to scab wheels ( leaving 2.5" on each side when loaded) and winch it in. pulled in, my front wheels are parked directly on top of the first axle.
