Can of Worms.. LT vs ST 13K trailer
Nutinelse2do
Morning,
Will try to keep this as simple as possible.
Doing the investigation of new tires. I was completely convinced to go with either Duravis or XPS LT tires . My rig GVWR is 12.7 loaded with 6k axles. So by the book I should be using ST tires which have a carrying capacity of 3500 each vs 3000 on LT.
Several questions.
If my rig has a GVWV of 12,700 why are there only 6k axles?
Does keystone subtract the pin weight from what the tires/axles should carry?
Would I be over stressing LT tires with the weight above?
Also concerned with what I have read about 65 mph and overheating on ST's
I know all the discussion on LT vs ST, but the above questions are my main concern. As always I am probably over thinking this, but we still have 9 months to go and it occupies my time.. 🙂
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
16 REPLIES 16
Dennis_M_M
Another vote for XPS Ribs
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
JIMNLIN
op asks wrote:
Several questions.
You answered your question although its not just Keystone that does this. Using 20 percent of 12700 GVWR has a 2570 lb pin wight or 10160 lbs on two axles or 2540 lbs per tire. The LT E at 3042 times four gives your trailer over 12000 lbs of tire capacity for a nice reserve capacity.
Absolutely not. We've used LT E at 3042 lbs capacity on 3/4 ton trucks 6000-6084 rear axles and 6k trailer axles for decades.
Using LT tires isn't a new thing out here in the real world of light trucking and trailers.
We used 14"/15" and 16" truck tires (LT) and P (passenger) tires for years before the tire industry gave us the infamous ST tire.
wandering1
Because that is all you need. Subtract the pin weight from the GVWR.
It depends entirely on the weight capacity of the tire. Read the sidewall.
Also concerned with what I have read about 65 mph and overheating on ST's. ST or LT, do not run the tires faster than the max speed on the sidewall. Higher speeds than what the tire is rated for will cause the tire to overheat which will damage the tire.
HR
NC_Hauler
I will make it close to unanimous...go with the Michelin XPS Ribs....as also stated earlier, 15% to 20% of whatever your 5er weighs loaded is pin weight which is carried by your truck, not by your 5th wheels axle's or tires....
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
Splashers3
I totally agree with BO Plenty....
XPX RIBS and sleep well at night!
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
rseymour21
x how ever many that is for the LT
I increase my wheel size from 15" to 16" just so I could pick LT! I have not been sorry!
2003 F250 7.3L
2008 Cougar 292RK
Allworth
Find some CAT scales and run it across hooked up to the truck. You will have a little over 10K on the axles. With a GVWR of 13,800 I have 10,540 loaded for extended travel.
LT
LT
LT
I like the B.F. Goodrich Commercial TA. Seems to be a good balance of price and wear. (LT245/75R16 LRE)
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
B_O__Plenty
Totally agree on using LT tires. My Ribs have been trouble free. There will NEVER be another ST tire on any rig of mine...I don't care what you ST lovers say. I've compared them side by side. ST is like a bicycle tire in comparison.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
FastEagle
Nutinelse2do wrote:
Morning,
Several questions.
Because the trailer's hitch weight is subtracted from the GVW and added to the tow vehicle.
Does keystone subtract the pin weight from what the tires/axles should carry? YES!
Would I be over stressing LT tires with the weight above? Probably not.
Also concerned with what I have read about 65 mph and overheating on ST's. I know all the discussion on LT vs ST, but the above questions are my main concern. As always I am probably over thinking this, but we still have 9 months to go and it occupies my time.. 🙂
When replacing ST tires that are listed on your trailer's certification label you are going to have to take on the responsibility for the change. Unless, the vehicle manufacturer will recommend another tire design or a retailer will take on the responsibility for you and do so with the bill of sale. Industry standards will not support the use of replacement tires with less load capacity than the OE tires. Tire manufacturers are very reluctant to warranty replacement tires they consider a misapplication.
FastEagle
Me_Again
rhagfo wrote:
Many will state ST are designed to take the sidewall stress of the tandem axle.
ST tires are the dirty little secret of trailering. There is nothing much special about them other than they dodge normal tire industry standard with inflated rating based on speed restrictions and the fact that they kill few people. And they are cheap, really cheap to the trailer manufacturers!
They are highly marketed by an small number of manufactures and importers. And they were troublesome way before manufacturing was moved to china.
Those with 6K axles and under are lucky in that there are many LT tires available that will give much better service, with the two the OP noted being two of the best.
Install them, trailer on and don't look back. They will roll down the road easier and be more stable. The closed outer rib on the XPS Rib and R250 does not grub in tight maneuvers. Go look at the trailer tires at a truck stop and see what the tread pattern looks like. Hint, it will not look like the current ST tires, but will resemble the Rib, R250 and GY G614 trailer tire.
Chris
Francesca_Knowl
rhagfo wrote:
There are no ST's in big trucks.
It's true that the descriptor "ST" isn't used on big truck tires, but there ARE bigrig tires designated by their makers as for use on trailer axles alone.
See "trailer Tires" section at This Michelin Longhaul truck tire page
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
rhagfo
Nutinelse2do wrote:
Morning,
Several questions.
I would rather run LT's closer to their Max load capacity, than ST tires with a larger margin. They cost more for a reason. Many will state ST are designed to take the sidewall stress of the tandem axle. Well commercial HDT run the same tires on all axles, drivers and trailers. There are no ST's in big trucks.
MrVan
The answer is LT tires only! No and No to ST tires of any type or size.
Campinfan
Your rig has 6K axles because they Mfg does not include the weight that will be on the pin or the landing gear.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
