Dave_Chandler
Feb 14, 2016Explorer
City water backflow into fresh water tank
I just solved the problem of city water feeding back through my pump and overfilling my fresh water tank. Since its almost new rig, I figured not changing the pump out just because of a little backflow.
I purchased an Aqua-Pro Fresh Water check valve #20818 at Camping World. Also called Backflow Preventer 56574 in their inventory. Cost $6.49.
Then off to Lowe's where I purchased two Brass Hose Barb LFA-390, adapter, 1/2 in ID x 1/2 in FIP. $3.99 each
I cut about 2" out of the line going from my frest water tank to my pump and put this in, with a couple 1/2 to 5/8" clamps, and a little teflon tape. Be sure to look for the arrow on the brass fitting showing the flow direction, you want it pointing toward the pump.
Let me know if this helped anyone out.
