- Ka_RonExplorerSounds like you just cleaned the awning??
- PwrRamExplorerOutdoor bleach works wonders cleaning the awning. spray the awning to wet it spray with bleach brush and hose off. looks like new
- twins89ExplorerHow to clean awning:
Lowes: One gallon pump sprayer of Tilex mold and mildew cleaner
Extend awning completely.
Spray 2-3 beginning at the roller edge on top and underside of awning, roll up to where you have sprayed
Continue to spray next 3 feet or so, roll up that much more
Finish spraying roll up awning completely
Wait 20 to 30 min.
Unroll, brush lightly on underside
Rinse thoroughly.
Results: Clean, bright awning - DutchmenSportExplorerNah-uh! Use Mr. Clean Magic Eraser.
- ScottGNomad
Wait 20 to 30 min.
Rinse thoroughly.
I've tried many different products and methods but this is the one that works. No hard work or scrubbing. The spots and stains just vanish. - Old-BiscuitExplorer III
How do you get it to spray on?
Much rather do the spray/roll up/drink a beverage/unroll & rinse method - 0rionExplorerthere's 2 things that I can't wait until my boy is old enough to do.....mow the grass and clean the awning.
- cpaulsenExplorerSame here...sprayer with bleach and Dawn dish soap....spray on underneath...roll up for about 20-30 minutes....unroll and rinse off.
- ACZLExplorer
Then come do my awning. - DHCamperExplorer
This is what Dometic recommends in the manual:
Mildew does not form on the fabric itself, but on the accumulated dust, dirt and grime. Periodically clean vinyl or woven acrylic fabric using a mixture of 1/4 cup of dish soap and 1/4 cup of bleach mixed with 5 gallons of warm water. Liberally slosh the mixture on the top of the fabric and roll the awning up for 5 minutes. This will apply the mixture to the bottom as well. Roll it back out and hose off with fresh water. Repeat if necessary.
Works great!
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
