oldminer's avatar
oldminer
CONVERTER LOCATION
where IS THE CONVERTER LOCATED in my Attitude 5th wheel trailer. It is a 2014 29 feet long toy hauler. Frig is on internal wall. Where on the internet might I look for the electrical system schematic for it? There is no fan noise/grate either.
  • mabynack wrote:
    Mine is behind the breaker panel. I had to take things apart to find it. My last RV had it under the dinette seat.
    X2
  • No telling where it is, logic does not play into the equation. For example: on our Newmar the land electric connects at the left rear and the batteries are in a drawer in the back bumper. So guess where the converter is … far RIGHT FRONT corner! Go figure.
  • On Titaniums they are behind the rear wall of the basement, accessible through a panel held on with Velcro tabs. Just to the Passenger's Side of center. The Water pump and brake hydraulic pump are behind the panel closest to the outside wall.
  • Mine is behind the breaker panel. I had to take things apart to find it. My last RV had it under the dinette seat.
  • dockmasterdave wrote:
    When I asked the factory about a schematic for mine, they said no way they would give me one.
    From what I have seem inside a typical construction, there probably isn't a written schematic per se. They throw these things together willy nilly and no two are exactly alike.
    If there were a standard schematic, why would they hand write the circuit labels on the breaker panel?
  • not a direct answer.. on my alpine, next to the fuse panel, there is a blank cabinet panel. remove the 2 screws and the panel comes off and the converter is mounted to the floor. No interior vent.
  • When I asked the factory about a schematic for mine, they said no way they would give me one.
    It is proprietary information.
    As far as I can tell, you are left to figure it out on your own, and it appears they are not all done the same. Even within a given year and model, they apparently change things.
    I agree the converter should be right near the fuse/breaker panel.
    Good luck with the schematic.
  • where IS THE CONVERTER LOCATED in my Attitude 5th wheel trailer. It is a 2014 29 feet long toy hauler. Frig is on internal wall. Where on the internet might I look for the electrical system schematic for it? There is no fan noise/grate either.
