- Gib3633ExplorerCummins 2014: If you read the original comment I sent you will see that I liked the 1 1/8 thickness of the jaw contact to the King pin on the B & W. If you check out the Curt Hitch the jaws appear to be about 9/16 thick. If you get up top and look at the inside of the jaws you will see that the contact part of the jaws to the king pin is only 3/16 of an inch . I think it will over time create a premature wear on the front side of the king pin and a sloppy connection.
As far as the common sense comment well maybe I didn't explain clearly enough what I just wrote above because the original post ordered a Curt hitch and if that works for him it works for me.
I think I also said at this time B&W did not make a hitch for GM over 20,0000lbs for the puck system. AT THIS TIME. It would only stand to reason since GM was 2 or 3 years behind Ford and Ram to install the puck system.
Hopefully I have explained myself more clearly this time. I only know for sure why I turned away from the Curt hitch which I almost ordered. - Cummins12V98Explorer III^^^^^ The 18K Companion I had prior to my 25K DID HAVE 1 1/8" jaws, my current 25K is 1" thick.
I'm guessing you bought your Ford because you felt it was the best truck? Are you saying the Curt is a better hitch than the B&W or just cheaper?
I don't own a Curt but I have unhitched one a couple times and it was not easy cheazy. - TravlingmanExplorer II
Gib3633 wrote:
To Me Again:
I spoke directly to B&W and they do not make over 20,000 lb. puck system for GM & Ford at this time not to say they won't in the future. I really liked the fact B&W had 1 1/8 thick contact on the pulling surface of the pin. Common sense means very little when the gentleman already had his mind set on the Curt, in which case I'm happy for him.
What SAE standard does B&W rate their hitch by? I see no mention on their site. The Curt meets SAE J2638. Also, you say B&W has a 1 1/8" contact. B&W states the jaw is 1" thick. Do you have a special build hitch with thicker jaws? Looks like somebody is missing some common sense in their measuring, don't you think?
By the way, I had a B&W before I bought a Curt. It was a good hitch, no problems, good customer service. Fortunately I am not a fanboy and will actually look at other products the same way I did before I bought my new truck. I guess I see no reason on spending more money on something that is rated to do less. Also found the majority who have an issue with a Curt hitch have never owned one and are in the B&W fanboy club.
I have already hooked up the Curt and am very pleased with it. - cummins2014Explorer
Gib3633 wrote:
To Me Again:
So what you are saying is that the B&W is rated for 20K ,and the Curt is 25K, so common sense means very little, I guess because the Curt should also be rated for 20K ? Could there possibly be a reason in the construction of the curt that makes them rated at 25K ????
I read this quite often, and wonder how some of these conclusions come about. :h - cummins2014Explorer
Cummins12V98 wrote:
Gib3633 wrote:
To Me Again:
They rate their hitches to the weakest link, what does that tell you? RAM puck RVK3600 is 25K.
It tells me the same thing all hitches do, they are rated for a certain weight for a reason, whatever their weakest link is. Not sure of your statement.
I am sure you are not trying to say that B&W is the only hitch that is rated correctly, that would a pretty long stretch. - cummins2014Explorer
Travlingman wrote:
Thanks for all the input. I ordered a Curt Q25 yesterday.
Good job. I managed to have a Reese that has served me well for several years, have no doubt the Curt will do the same. - Cummins12V98Explorer III
Gib3633 wrote:
To Me Again:
They rate their hitches to the weakest link, what does that tell you? RAM puck RVK3600 is 25K. - Gib3633ExplorerTo Me Again:
I spoke directly to B&W and they do not make over 20,000 lb. puck system for GM & Ford at this time not to say they won't in the future. I really liked the fact B&W had 1 1/8 thick contact on the pulling surface of the pin. Common sense means very little when the gentleman already had his mind set on the Curt, in which case I'm happy for him. - 53_willysExplorerI have a new Curt Q16 and absolutely love the hitch much better hitch than my old Husky 16K .
- Me_AgainExplorer III
Gib3633 wrote:
I was looking at the Q24 for the puck system for the new GMC and Curt was the only one found and probably the reason endorsed by GM. upon closer inspection I was looking at the jaws and closed they look about 5/8 inch thick . However if you look at the inside of the jaws where contact is being made with the king pin the contact is 3/16 inch thick. I feel has to create an early wear factor on the king pin.
The 20000 lb. B&W has jaw contact of 1 1/8 inch on the inside contacting the pin. B&W are not yet producing anything heavier than 20000 lb. at this time for puck system GMC only RAM.
I suppose if I were delivering trailers for a living I wouldn't be overly concerned
After these discoveries my 20,000 lb. Reese with jaws 1 inch outside and 5/8 inside looked pretty good and I just purchased the adaptors from Pullrite to convert puck system to regular fifth wheel hitch. If they become unsatisfactory possibly B&W will have their heavier hitch available for GM
I would think the head for the RAM is the same as the Ford and GM one. B&W derates the Ford and GM hitches base on the mounting system not the head. Think spread of base legs.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
