- ol_Bombero-JCExplorer
remoandiris wrote:
Thanks all. Hole saw it is. The new unit likely has a designated spot to cut the vent hole. At least the 2013 version I saw had the spot designated. I ass-u-me the 2014 version does as well.
How about calling the trlr mfg's tech line and ask?..:h
~ - remoandirisExplorerThanks all. Hole saw it is. The new unit likely has a designated spot to cut the vent hole. At least the 2013 version I saw had the spot designated. I ass-u-me the 2014 version does as well.
- Cummins12V98Explorer III
Lantley wrote:
larry barnhart wrote:
Cummins12V98 wrote:
Lantley wrote:
4" hole saw
Too small!
The pipe is 4" . 4 1/4" would be better.
My total work experience has been in construction and including myself at times without the correct tool it is usually a bigger problem with the hole too tight.
tools are everything.
chevman
If we want to get technical what is the outside diameter of the hood or discharge cover being used?
It all depends on the model. Measure what you are using and size the hole about 1/4" larger than what goes thru the wall. - LantleyNomad
Cummins12V98 wrote:
Lantley wrote:
4" hole saw
Too small!
chevman
If we want to get technical what is the outside diameter of the hood or discharge cover being used? - Atom_AntExplorer
BuckBarker wrote:
It better hit something, unless you are totally un-insulated! :E
Start with a small hole from the inside and bend a coat hanger at 90 degrees and insert into the hole. Spin the hanger all around and if it doesn't hit on anything then you are good.
I've installed my dryer vent in 3 different rigs now with the same 4" hole saw. Use the morning dew to find the studs, use some common sense to avoid the electrical, and go for it. I go from the outside in, then go inside and finish through the same pilot hole. The 4" hole saw is about 1/2" short of going all the way through which avoids any splintering of wood or chipping of gel as experienced when drilling all the way through from one side.
I've kept the plugs from all of them as a joke for coasters. They are laminated wood sandwiched over a Styrofoam core. - larry_barnhartExplorer
Cummins12V98 wrote:
Lantley wrote:
4" hole saw
Too small!
chevman - Cummins12V98Explorer III
Lantley wrote:
4" hole saw
Too small!
The pipe is 4" . 4 1/4" would be better. - LantleyNomad
donn0128 wrote:
JIMNLIN wrote:
Make sure your exploration hole isn't bigger than the pilot on the hole saw. just sayin'.......
Or make the pilot hole next to the bigger hole if there is room.
Or do it from inside?
If in doubt Make a smaller exploration hole on the inside - donn0128Explorer II
Or do it from inside? - midnightsadieExplorer IIand tape it on both sides helps with chiping. do all the above I,realy like the 4inch plus hole ,makes easy slideing the pipe thru.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
