Camping for the week and I'm noticing the ac is not kicking off. But instead it seems like the compressor turns off and the fan keeps blowing after a 5 sec delay. The. A few minutes later the compressor kicks back on. Usually when we wake up in the morning when it hits desired temp the whole system shuts down until it heats up again. Is this normal and I just never noticed it? Also once or twice a day it sounds like something is shooting out the ac down the vent lines. Almost like you threw some beads down a metal tube. I'm guessing it might ice or something breaking off from the ac. Anyone else have this? Our previous jayco never did this. Thanks
I have a Cyclone 4014. The a/c must be set to auto. If you are set on hi or low it won't work correctly. There is a lot of discussion on the Heartland Owners Forum regarding this issue.
I believe its when the fan is set to manual; it 'seems' to run at a higher speed when the pump is on then drop in speed when the pump is off. But there is a short delay between the fan speed changes.
I also didn't notice it until the last trip this year
