seahunter_1's avatar
seahunter_1
Domestic fridge flashing E1 code .
Hi everyone
I have a 2009 Cardinal fifth wheel with a Dometic fridge .model number RM 3962 .
I changed my house batteries about a month ago and ever since my fridge flashes the E1 code . I have done what it says in the manual to reset it ,,thatbdoesn't work ,,I've had a service person from Triagle rv out here and he thought he reset it,,,twenty minutes after he left ( and left me with a big bill ) my fridge is flashing again . The fridge works fine ,,,but I would like to know ,,other turning the fridge off and on again when the code comes on ,,,,,,,is there a fix for my not too serious problem ??
The service guy said the E1 code is stuck in the fridge,'s memory ,,,ya ,,so what ??
Thanks to all who answer .
Seahunter 1
Vancouver Island ,,full timer .
  • Never heard of using a magnet to reset a fault code.....reset a Norcold Recall Box yes but not a fault code :H
    Anyway.....
    Normally an E1 code is a 'hardware fault in the gas operation system'-----problem with igniter or gas valve.
    BUT if you are getting the E1 fault code when using AC and Gas operation it could be a faulty thermistor (temp sensing probe in food section clipped to fin)
    Dometic Thermistor/ Conductor (3851059042)
    To test the Dometic thermistor, disconnect it from the main (lower) circuit board and place the other end (sensor end) into a glass of ice water (mostly ice). After a few minutes you should be able to get a resistance reading of 7,000 to 10,000 ohms between the two terminals of the connector. If the resistance isn't close to those numbers, it is bad.
    You can just replace the sensor tip if thermistor is bad
    Dometic Snip-the-tip repair kit.......LINK
  • Since the frig seems to be working fine, I'd say all you need to do is clear the fault code.
    i have heard (here on the Forum) that passing a small magnet in front of the switch will clear the code.
    Disclaimer: I've never had an error code and have never had to clear one so let me know if it works.
