- GeorgeRenisonExplorerThanks very much
It is the120 volt hot water heater switch.
George - GeorgeRenisonExplorerEveryone thanks
I will try them this weekend when we are Camping
VR
George - old_guyExplorertry turning off the pump at the other station in the kitchen or where it is at and then go into the bathroom and turn on that switch and see if the water pump works. if it does, then you know what it may be for.
- roy67ssExplorerHow about propane water heater switch?
- bad99ramExplorer
Old-Biscuit wrote:
Water pump?
So you don't have to run downstairs with your pants around your ankles to get water to flush toilet......just my guess :B
X2 - mayo30Explorer120 volt water heater element.
- 1492ModeratorMoved from Forum Technical Support
- tvman44ExplorerProbably the electric heat for the hot water tank. :)
- ScottGNomadIn older trailers that was sometimes the electric tank heaters.
- Ka_RonExplorerCould very well be water pump, or in our RV the light switch (Domestic style switch) is for the 110 for the water heater.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
