RCMAN46
Dec 05, 2015Explorer
dehaile wrote:
Hello. We lost two tires on same axle and had to tow trailer a couple of miles to get to town. We were towing on the rear axle at a very slow speed for just a small distance. After putting the tires back on, we noticed the equa-flex suspension is facing downward and not upward so that the axles are straight. When we lower the trailer, the equaflex hangers just pins itself to the side... still facing down. We did not unbolt the equaflex or the leaf springs. How did this happen? How do we fix? Will it happen again by just raising the suspension? Thanks
With the trailer as show in first picture with the tires off the ground take a second jack and jack the axle up and the hanger will probably flip back to correct position.
And yes it may happen again when you lift all the tires off the ground.
Two tires failing on same axle indicates that axle is overloaded. Is the trailer level when towing?
Suggest getting individual axle weights at a Cat or other local scale.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 24, 2025
