fj12ryder wrote:
jshupe wrote:
I was just saying it's taken into consideration. I would never advise pulling anything more than a pop-up or teardrop without trailer brakes, just to be clear.
I don't think brakes are prone enough to failure to worry about them any more than a blow out, and shouldn't be the deciding factor for a vehicle as long as you are within the stated GCWR for your TV.
There's an awful lot of people running TPMS that don't feel quite the same as you when it comes to blowouts. :)
Brakes do fail: wires do short out, umbilical cords get ripped out or worn by dragging on the pavement, grease gets on the brake linings making the trailer brakes perform very badly. IOW stuff sometimes just happens. Not often, but I've read about all of the above happening to people that post on this forum.
I run TPMS on my trailer but am not overly concerned about a blowout. It just makes sense to closely monitor such things. Proper maintenance and care goes a long way to prevent failures. Most of the things you addressed are products of either neglect or incorrect maintenance.
Trailer tires generally suck. You have to keep them out of the sunlight as much as possible, keep them aired to the proper inflation via load tables (or max, in many of our cases), keep your speed within their limits, keep their load within their limits, be careful not to rub them on curbs, and not let them age beyond a certain point. It's a pain in the ass to stay on top of those things but not doing so is the reason most people have blowouts.
Wires don't short out for no reason. Brake wires need to be inspected. EOH lines need to be inspected.
If your umbilical cord gets ripped out, you are routing it incorrectly.
If your umbilical cord is dragging on the pavement... see above.
If you get grease on your brake linings, you aren't taking proper care when packing your bearings or replacing your shoes/ pads. Or you're using the wrong type of grease, or letting your seals wear out.
Brake controller failure is an example of an occurrence that can't be helped with proper care and attention. But it's exceedingly rare.
