mr__old_style
Jun 02, 2013Explorer
Fresh water tank question
Need a little help in understanding the layout of my freshwater tanks.
I have two tanks 55 gallons each approx. There connected together near the bottom with an approx. 1 1/4" hose. Without pulling them down I cant see all the connections, but it appears each tank has a couple vent lines in the top, I believe the fill line comes into one of them and flows into the second via the 1 1/4" line. I also believe the rear tank has a 1/2" or so line that runs to the pump. That 1 1/4" line that connects the two tanks is close to 1 1/2" up on the sidewall of the tank. That being the case that front tank always has at least and inch and a half of water in it. Is that common or is there a suction line going into that front tank that I'm not seeing. Seriously considering pulling the tanks out and putting the connector line down on the bottom of the front tank and raising it up a little, (or dropping the rear tank down) so the water has a chance to flow into second tank. Any thoughts?
2008 Cyclone 3912
2008 Cyclone 3912
