- lincsterExplorerSooooooo....... does that mean it works now?
- coolbreeze01ExplorerReplaced the white gears in the pump with the gray gears I bought from GPI.
Yes, it works lincster :C - naytherExplorermost, if not all, have a switch inside plus a windup timer or switch out at the fuel station.
- lincsterExplorer
allcool wrote:
coolbreeze01 wrote:
Green light comes on, fuse isn't blown, but the pump doesn't work.
No noise, nothing.
Ideas appreciated.
1) Go directly to pump. Check Directly AT pump, not at switch or fuse or any other place, with a volt meter check for 12v at pump. If no 12v at pump, disconnect trailer wires and use jumper wires to supply 12v directly to pump.
2)If 12v is present directly at pump, and pump runs, check wiring/switch/fuse/fuse holder/timer/etc.
3)If 12v is present directly at pump, and pump does not run, carefully disconnect and take out pump.
4)Remove pump cover plate to expose gears. Take out gears and then apply 12volts to pump. If pump motor runs, its the gears. If pump does not run, its the pump motor.
5) Repair and or replace as needed...
jmo
X2 - DirtclodsExplorer IIIf you have a switch at the pump check that as well.
- allcoolExplorer
No noise, nothing.
Ideas appreciated.
1) Go directly to pump. Check Directly AT pump, not at switch or fuse or any other place, with a volt meter check for 12v at pump. If no 12v at pump, check wiring/switch/fuse/fuse holder/timer/etc.
2)If 12v is present directly at pump, and pump does not run, carefully disconnect and take out pump.
3)Remove pump cover plate to expose gears. Take out gears and then apply 12volts to pump. If pump motor runs, its the gears. If pump does not run, its the pump motor.
4) Repair and or replace as needed...
jmo - coolbreeze01ExplorerIts the trailer's GPI gas pump. I don't think its the gears. Supposed to be the non-swelling upgrade. If the gears were jammed, seems like the fuse would blow.
Pump doesn't run but op light comes on and the gauge works. - joebedfordNomad IIFuel pump for . . . ?
I'm guessing your gears have swollen and need to be sanded down (but it could be a different pump).
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
