โSep-05-2016 12:01 PM
โSep-06-2016 04:48 PM
โSep-06-2016 03:21 PM
โSep-06-2016 01:42 PM
tinner12002 wrote:wilber1 wrote:
I've never heard the term "towed weight" before but it makes sense that hitch manufacturers would use some combination of towed weight and pin weight in order to rate their hitches.
The placard on my Draw-Tite 16K slider reads, "Max gross trailer weight 16,000 lbs. Max pin weight 4000 lbs." No mention of towed weight.
That's two different things unless your 16000# RV has a pin weight of 4000# then your maxed out on your hitch ratings even though your RV now may only weigh 12000# at the axles, at least that's the way I understand it. The 4000# is still part of your RV and is loaded on your hitch in a pull mode.
โSep-06-2016 12:28 PM
โSep-06-2016 12:22 PM
โSep-06-2016 11:03 AM
โSep-06-2016 10:18 AM
clev wrote:I have no problems with Curt's explanation of tow dynamics. The problem lies with your interpretation thereof.
Good grief members, let this die. I have agreed with the definition of gcwr since the beginning, I have agreed that my example exceeds the gcwr of the TV, I have agreed with pin and axle weight definitions. The only disagreement is that "I choose" to accept the definition of 'towed' weight as defined by Curt. It does not change gcwr and it does not change payload. It's "My choice"; you don't have to accept Curt's definition. Geez! Give it a rest.
โSep-06-2016 10:07 AM
โSep-06-2016 10:00 AM
โSep-06-2016 09:54 AM
โSep-06-2016 09:51 AM
clev wrote:If you're referencing my last post, then clearly we have a failure to communicate. If not, my apologies. Please disregard the next paragraph.
My quote: " 'towed' weight of 15.5 k. That has no effect on gcwr, and I know that"
Your entire post is basically what I have repeatedly posted.
โSep-06-2016 09:44 AM
Beverley&Ken wrote:
Quote " Fact: the trucks specs will allow up to 3700 pounds on the rear axle. I'm good on everything except gcwr. I'll have to load very carefully. "
Is that 3700 pounds the rear axle rating , which would include the weight of the truck,(box, fuel, suspension etc, hitch and cargo) or is it the cargo carrying capacity not counting whats all ready part of the truck?
Ken
โSep-06-2016 09:41 AM
