Aug-10-2022 08:25 PM
Aug-17-2022 09:24 AM
Aug-17-2022 07:53 AM
Aug-11-2022 09:53 AM
cptqueeg wrote:
When sizing residential AC, both window and central air, I was always told that too big of a unit will not run long enough to remove the humidity. Perhaps just running 1 or 2 of the 3 units will solve your issue as it seems you achieve your desired temperature under relatively mild conditions before the air gets dehumidified.
The other suggestions about preventing or eliminating sources of humid, outdoor air and moisture are good ones.
Aug-11-2022 09:35 AM
Aug-11-2022 09:27 AM
Aug-11-2022 09:18 AM
kkirt1 wrote:
Thanks for the advice. Still curious as why for the first few years it didn't seem to be an issue. Now very noticeable. Wondering if there is something about the settings (temperature, fan speed, fan mode) that has started this humidity spiral.
Aug-11-2022 08:06 AM
Aug-11-2022 07:06 AM
Aug-11-2022 06:57 AM
Aug-11-2022 06:04 AM
eHoefler wrote:
Showers, cooking, etc.. all add humidity, particularly showers. Use the bath vent when showering and the exhaust fan when cooking to help reduce the humidity. Running a stand alone dehumidifier would help dramatically.
Aug-11-2022 04:53 AM
Aug-11-2022 04:34 AM
Aug-10-2022 09:25 PM
