allen8106
Apr 28, 2020Explorer
Hitch and Pin Box Replacement
OK guys need your opinions, looking to replace my hitch and 5th wheel pin box. Hitch is a 10 year old Reese 15k Pro Series with a flat sliding bar to capture the king pin with about 35k miles of towing. The bar has developed a 1/4 moon shaped groove about 1/4" deep. The king pin on the camper has also developed about an 1/8"-3/16" deep grove in it and is 10 years old also. Jayco tells me the king pin isn't replaceable and the entire pin box has to be replaced. Reese tells me the slide bar on the hitch isn't replaceable and the entire hitch head has to be replaced.
I've always been told a weld is stronger than the original material so have considered just having a friend weld both to fill the grooves and move on but worry about long term viability of both.
As a result I'm considering just biting the bullet and replacing both with new. My truck is a 2018 GMC 3500 DRW with an 8' bed and the OEM puck system.
I'm considering a B&W Companion from my local RV parts shop for $1,045 + tax. I have no idea what I want or need for the pin box.
Thoughts?
Thoughts?
