RAINEYTXX wrote:
Lantley wrote:
RAINEYTXX wrote:
OK-in my experience if you have electric AND propane and are connected to shore power-why not use both? We heat using both: keeps the critters out of the burner and quick recovery times! Why stress about a choice? Use both and have fun!
Because electric is included in the price of admission and propane is not. Therefore it is more cost effective to use propane only as needed. In the end propane adds an additional cost.
For the immediate time...then we all have to agree that if the campground owner raises the daily/weekly rate to compensate for the added electric useage to make his bottom line, we have to promise to not complain!
I hear you Rainey, It sort of a no win scenario.
However the CG owner has already raised the rates. You are paying a flat rate that covers your electric usage for A/C and hot water regardless if you use it or not.
Don't expect a refund if you dialed back your thermostat or ran your water heater exclusively on propane! Your going to pay the same rate if you conserve or if you run everything full blast. Of course I'm referring to weekend camping and not seasonal camping that may have metered electric.
