- capacitorExplorerThe link didn’t work check Amazon for rv vinyl trim.
- capacitorExplorerThat looks like rv vinyl trim that tucks into a track. If so, replace it.
https://www.amazon.com/RVMATE-Insert-Trailer-Camper-Travel/dp/B08HPTVM5D/ref=mp_s_a_1_1_sspa?dchild=1&keywords=rv+vinyl+trim&qid=1629143961&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyTDFFR1VTN0hOT0sxJmVuY3J5cHRlZElkPUEwMjg5MDgyNjZIMjZBSE9QOVBPJmVuY3J5cHRlZEFkSWQ9QTAzODMzMTYzUUFGVEJLNlFVQksxJndpZGdldE5hbWU9c3BfcGhvbmVfc2VhcmNoX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= - VeebyesExplorer IIThere are many types of adhesives. 40 plus years of boating here.
Whatever you use, do NOT use 3M 5200. That stuff is nasty. Intended for below waterline use & for things that will never ever, ever have a reason to be removed such as deck to hull bonding. Been there. regretted using that.
Get some 3M 4200, or similar. It bonds nicely to clean surfaces & makes a nice clean edge between surfaces by running an ice cube along the joint before the product skins over. - ssthrdExplorerMarine adhesive would be perfect.
- NRALIFRExplorerWide trim like that is often stuck with 3M VHB tape, about 1/2” wide, one strip along each edge on the backside.
:):) - TXicemanExplorer IIAutomotive trim adhesive.
Ken - Edd505ExplorerCheck an auto parts store they carry a adhesive for trim.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
