hammer21661's avatar
hammer21661
I put the 19.5 inch tires and wheels on the fuzion.
I got tired of having the china bomb blow outs. 2 blew and one broke belts,I was lucky enough to see it before it blew.This all happened in a year and a half.I have been on this site looking for info. I got a few bits and pieces and found a diesel power article my brother told me about.I saw one guy typed that was the best thing he did on his 5er.
So this is what I did. I got the vision wheel hauler 81 part #81A9781MO this has the standard center cap this wasn't deep enough for mine so I had to replace my dust caps that were barely short enough. I don't know if the deep center cap would be sticking out too far your liking but you could just put it on with no worries. This wheel is rated for 4500 lbs.There is a black (81A9781MBO) one and the machined finish(mine) available.
This leads us to tires, I got the Dunlop SP348 in a 225/70r19.5 these are g rated at 3,9?? lbs each so I have a little wiggle room on capacity.the Fuzion 322 has tandem axles and a big space between the tires so clearance isn't an issue. the height is about 1.5 to 2 inches higher then the original 235/80r16 that it came with.I have at least 4 inches clearance over the tires. I had previously added the Mor/Ryde SRE/4000 center links.This may have got me some more clearance but also increases the tire travel.
This is what I did i would have loved to have been able to just use a michelin rib but they were not rated for the weight of the rig the good year g 614 was but had a 75 mph speed rating, st tires were worse at 65 mph. Right or wrong this is what I did I can only wish anyone the best of luck with whatever they decide to do.
I got prices on everything the Bfg ST230 steering tire was cheaper by a few dollars but none were available and we had no date for when they would be. So I have just about $500 per tire and wheel.I believe the commercial tire is a good route to take for longevity. the rim is made in china but I was pleasently surprised with the visual quality of the rim. The tires are made in the U.S.A. mine had a date code of 1114 and I got them a week ago so another plus.
I hope this helps someone with a choice and cuts out some guess work for you. Again good luck with your choice.
