aruba5er
Aug 17, 2017Explorer
Rv's typically do not have a box which contains the outlet so the standard outlet has no where to fasten to the wall and the wires that connect the outlet are exposed. And the walls are usually too thin for a regular box. you could take an old work box and cut the sides off to fit in a regular outlet I guess. For safetys sake buy an outlet from a RV dealer and forget the USB. Use the charger that came with the devise.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
