- gtnsmlrExplorerThere's actually 3 parts. The reduction gearbox between the motor and leg, easy to disassemble clean and regrease. The bevel gear on top of the leg, easy to disassemble and regrease. and lastly, the jack screw in the leg. I have 6 of these jacks in my leveling system and it takes me about an hour per jack to pull it off tear it down clean and regrease. The front jacks take a bit longer to get out and reinstall. Take pictures to make sure you orientate the parts properly.
- C_SchomerExplorerYep!
- Dave_H_MExplorer IICraig, that keeps the rust down on my landing gear feet also. :R
- C_SchomerExplorerThere was plenty of grease at the top gears and bushings. I drilled 1/8" holes about 3" down from the top of the outer tube and stuck a wire in the hole to be sure I could feel the screws. Then I spayed gear lube in there for a few days til it was coming out the bottom. I know them suckers are lubed... I was wiping the grease off the bottom, all last year! Craig
- Old-BiscuitExplorer IIIAs for the 'legs'
With 5vr hitched I drop inner leg and spray it with a graphite lube.....goes on wet then dries.
Then exercise the inner leg up/down
Afterwards I dun outer leg down and spray the upper portion then fully retract
Give it a light spray every couple months of use as I am breaking camp
Simple....takes maybe 5 minutes - Greyhound_RBExplorerThank you for your help
- MFLNomad II
Dave H M wrote:
as MLF says. Mine are located on the back side where they are hard to see much less grease. :h
Makes no sense, but typical. :)
Mine are easy to see, not on back side, but a flex hose on grease gun still needed, due to other obstacles.
Jerry - Dave_H_MExplorer IIas MLF says. Mine are located on the back side where they are hard to see much less grease. :h
- MFLNomad IIMy landing legs came with factory installed zerks, one on each leg, in the area of the lower one, in Old Biscuit's picture. It only takes about 2 pumps on the lever to grease.
I think the grease is applied right near the large nut, so grease is spread up/down, and through the nut. It made my leg operation easier, quieter, so yes, a noticeable difference.
Jerry - fj12ryderExplorer IIIThose landing gear motors are not very strong, or very reliable.
But if I were to try to lubricate the screw, I would run the screw near to the upper limit, then drill a hole through both legs fairly far down the leg inside the trailer, and spray lithium grease through the hole onto the screw. that way you can rely on the grease getting on the screw and the threaded mechanism too.
Using a zerk may only put grease between the two parts of the leg and get no grease on the screw, where it's needed.
I have heard of someone pulling the inner leg all the way out, and putting some grease on a piece of angle iron, and putting it up against the screw while running the motor. More work, but does about the same as the two holes and lithium spray grease
FWIW, I replaced the single motor system on my Fuzion with the dual motor system from Bulldog. Works very, very well, albeit a bit pricey.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
