Dec-19-2016 03:53 PM
Mar-22-2017 10:21 AM
Mar-22-2017 07:29 AM
Feb-28-2017 05:33 PM
Dec-22-2016 04:41 PM
greende wrote:
I had two of my 3 slide outs squeal. I found info on LCIs website on the procedure for lubricating the gear pack. I do not know how to do links. Go to the LCI website, click on customer service at the very top of the page and click on the Slideout tab, then through frame tab, then 2 X 2 Electric slide mechanism, Manuals, then click service manual and it is on page 9. I did this on mine and it quieted it down significantly.
Dec-20-2016 05:06 PM
Dec-20-2016 01:05 PM
Dec-20-2016 09:28 AM
greende wrote:
See my post above
about the gear pack. It stopped my squealing.
Dec-20-2016 08:38 AM
Dec-20-2016 07:46 AM
FLY 4 FUN wrote:
So is it your large slide on the drivers side? I am having a similar issue with my dinette slide, and it does sound like metal on metal. Looking underneath I wonder if its where the ram goes into the pass-through hole of the frame? There might be something to the rubber also as now that mine's a year old im sure the rubber is less pliable. I did use brake cleaner on all the exposed "workings" I could see and then used a light dry silicone spray on cogs/gears etc but no change. Im wondering if when the slide "tips" as it comes in if the floor is just dragging on an area that should have had a wear strip...
For sure let us know if you track it down, possibly with pics as there is no way im going to a dealer as they will say its normal. I don't think that a loud squeal inside and out is normal and may lead to wear on a part I cant fix easily or cheap.
Daryll
Dec-20-2016 05:50 AM
Dec-20-2016 04:18 AM
Dec-20-2016 02:07 AM
Dec-20-2016 02:06 AM
2oldman wrote:
It's probably the slide rubber. No big deal. You can try silicone lube spray.
Dec-20-2016 01:52 AM
