Leaving 5th Wheel for an extended Period
ventrman
When leaving my 5th Wheel for an extended Period without Electric hooked up, how long will my Frig work on a full 30 Pound Propane Tank?
God Bless!
21 REPLIES 21
n7bsn
FYI
You are all correct about current refers. Older refers didn't need a battery, they ran the flame all the time with no ignitor or 12V needed.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
DutchmenSport
Probably about 3 days as your battery will also have other parasitic draw too. Refer needs the battery.
phillyg
I'd trust one 12v battery no more than three days, and maybe five days with two 12v batteries. If you have 6v batteries, you might get a couple more days. Bottom line is you don't want to overestimate and have a smelly mess upon your return.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
JesLookin
MFL wrote:
SabreCanuck wrote:
Longer than your battery unless you have solar.
Yup, this, you need battery power to run fridge.
Jerry
The frig runs on propane, but also needs 12Vdc for the control circuitry.
2013 Arctic Fox 27-5L
2014 Ram 3500 6.7L CTD, Crew Cab
MFL
Nomad II
Nomad II
Jerry
Sam_Spade
Depends.....on size of frig, how low it's set and what the outside temp is.
I don't understand why anyone would think that is a good thing to do however.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
SabreCanuck
2011 GMC 2500 D-Max Denali
2015 Palomino Columbus 325RL
Our kids have 4 legs. ๐Ÿ™‚
