โJun-24-2021 09:11 AM
โSep-01-2024 11:46 AM
I have a 2012 Cameo and I have switched most of my lights from Halogen to LED. It is easy. Just be sure you get a compatable bulb. If you search your bulb number and look for LED replacement, you will be okay. We are full timers, so because I pay my own electric bill I changed. I got 6000K white. If your switch is dimmable, be sure the led is.
โAug-14-2024 09:24 PM
You can definitely swap out those super bright LEDs for something softer! Such as dimmable LED optionsโthey allow you to adjust the brightness to your liking without needing to replace the entire fixture. It's usually a simple switch and not too costly per fixture. This way, you can keep the benefits of LED while getting the softer light you want. You can search here, maybe there is something you need: lumazlife LED Lights
โJul-10-2021 09:13 AM
โJun-24-2021 07:17 PM
โJun-24-2021 06:18 PM
CA Traveler wrote:
Check carefully as incandescents take 6x+ the power (hence heat) of LEDs. Could also be a wire size issue.
โJun-24-2021 02:20 PM
โJun-24-2021 12:52 PM
โJun-24-2021 12:25 PM
โJun-24-2021 12:09 PM
nhshep wrote:Maybe others can chime in on an easier way.
Could not attach picture.
โJun-24-2021 11:48 AM
โJun-24-2021 11:29 AM
โJun-24-2021 10:28 AM
โJun-24-2021 10:17 AM
โJun-24-2021 09:59 AM
