- sayoungExplorer
ivbinconned wrote:
How did you arrive at that? Was your original a 122108?
Tape measure. No OEM shocks just brackets . My axles are under Springs. - ivbinconnedExplorer IISo in effect the shock has acted as a limit to how high the axel can react to a bump up.
- ivbinconnedExplorer IIIn fact drivers side rear the shock was with in 1/4 inch of full compression.
Shock absorber in looks only. - ivbinconnedExplorer IIMy Conclusion is this. Not enough distance was provided by brackets for original shocks. There for I am welding a new bracket on old one to add travel for the new shocks.
All original shocks show damage from collapsing to 0 plus.
Very poor quality work by manufacture. - ivbinconnedExplorer IIThat shock would be even longer.
I phoned Monroe. The 555001 has 4 inches of play.
With new springs installed about 10,000 miles ago (and I added an extra leaf)
Now with the suspension bearing the weight of the trailer there is only about 3/4 inch of compression left!!
This can not be good. I phone Monroe. They tell me they like to see 60% possible compression left !! - ivbinconnedExplorer IIHow did you arrive at that? Was your original a 122108?
- sayoungExplorerI used a Monroe 555025.
- ivbinconnedExplorer IIDid you see my second post?
- Cummins12V98Explorer III
ivbinconned wrote:
Ok Cummins about to install the number on the old is 122108.
The Munroe number 5550001 seems to be about 1/2 inch longer compressed.
Might this be a problem?
Monroe has a chart showing connection types and compressed/extended lengths. I doubt it would matter but check specs to be sure. - ivbinconnedExplorer IIMore info. Obviously the old shocks were bottoming out as the cupped washers are driven down over the nut on the end of the tube.
I installed the new shock. Installed the wheel, let down the jack.
Now I measured the new shock with weight on it. It is with in 1/2 inch of bottoming out!!
Not good.
I’m considering this. Welding a short piece of angle iron onto the top bracket and adding 1/2 inch or perhaps a full inch distance between the to mounting positions.
This would also give a more vertical position to the shock too.
Thoughts?
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
