Tequila
Nov 28, 2015Explorer
pianotuna wrote:
Hi,
You may wish to look at the cheaper Xantrex Prowatt line.
http://www.bestconverter.com/Prowatt-SW1000-Sine-Wave-Inverter_p_374.html#.VlkNcF7k-1t
$287 for the 1000 watt and $347.50 for the 2000 watt.
I'd go with the 2000 watt as the extra capacity means the inverter won't often be working hard.
Ok I used to be an electrician and I have to comment on this. First of all, inverters do not work hard. If they have the capacity, they can handle more draw on them. a 1000 watt inverter feeding a 200 watt draw is no less efficient than an 2000 watt inverter doing the same. The big thing is that the larger the invertor, the heavier the guage of wire you require to feed them from The Battery, and the closer to the battery it probably needs to be. I am sure there are plenty of do it yourself instalations out there that are a fire waiting to happen. A 2000 watt inverter requires a pretty heafty battery feed, something like #4 depending on how far away the battery is. Good idea ot load up your inverter with all the stuff you could conceivably run off it and feel that battery feed wire. If it's warm you have an issue.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
