- billyray50Explorer
goducks10 wrote:
Must've been a while since you've looked a diesel trucks since they all come with a 'Jake Brake' now.
Any of the 1 ton DRW will safely tow that 5th wheel. Test drive them all. They're different in their own way but all have the power and handling to tow your 5th wheel.
x2 - gitane59Explorer III
larry barnhart wrote:
goducks10 wrote:
I take mine to the local Ram dealer so it's not my problem where the oil filter is. @64 years young I'm done doing oil changes.
76 and I do my oil changes etc. Don't know why??
chevman
I do my own after the last dealer shop I took my Ford to left my oil filler cap sitting on the passengers battery and the service advisor gave me a maintenance status report from a Ford Focus when I went to settle the account.
My first clue that the maintenance report was wrong was that it said only 5 quarts of oil was installed. :E - cummins2014Explorer
Cummins12V98 wrote:
davidaf wrote:
I pull my Landmark Newport with a 16 Ram. Pulls and handles the load just fine. I have bags on the truck but they were added for my Lance camper I don't add any air for the Landmark. I suspect the 450 non-CC version will squat more (I owned a 2015 450, tongue weight is over 4k) based on how it handled my camper (5k lbs) vs the Ram. I never towed the Landmark with the 450 as it wouldn't stay out of the shop long enough to make it to make it a good tow vehicle for me. Towed like a bull but couldn't keep it on the road. The Landmark was bought after I swapped tow vehicles.
Running your bags at 5psi unloaded will make them about 30psi with your load!
Not true I set my air bags for whatever air pressure I want and it automatically adjusts to that setting. If I set it for 5 psi and put a load on the truck it will let out air to maintain that 5 psi. Or I can program certain air pressures and they do the same. That's what is sweet over OEM air ride where you have no control
As far as 5 psi turning into whatever psi when loaded with aftermarket air bags it's a pretty simple solution , let some air out to the desired psi it's not complicated. Another feature OEM air ride does not have - Cummins12V98Explorer III
Running your bags at 5psi unloaded will make them about 30psi with your load! - Cummins12V98Explorer III
stickdog wrote:
I going with with a F350 CC Lariat DRW 6.7 4.10 to pull the new DRV MS we're picking up at the end of the month with a 19,000 gvw. I've been told to go with the 3.55 which might be fine on the flats but we do the mountains as well.
Be sure to have the risers on your DRV or you WILL be nose high on the RV. - davidafExplorerI pull my Landmark Newport with a 16 Ram. Pulls and handles the load just fine. I have bags on the truck but they were added for my Lance camper I don't add any air for the Landmark. I suspect the 450 non-CC version will squat more (I owned a 2015 450, tongue weight is over 4k) based on how it handled my camper (5k lbs) vs the Ram. I never towed the Landmark with the 450 as it wouldn't stay out of the shop long enough to make it to make it a good tow vehicle for me. Towed like a bull but couldn't keep it on the road. The Landmark was bought after I swapped tow vehicles.
- stickdogExplorerI going with with a F350 CC Lariat DRW 6.7 4.10 to pull the new DRV MS we're picking up at the end of the month with a 19,000 gvw. I've been told to go with the 3.55 which might be fine on the flats but we do the mountains as well.
- 2oldmanExplorer II
ol Bombero-JC wrote:
Yes, a converted HDT is what many do.. but sometimes those rigs end up looking pretty horrid if you're only into the utilitarian version. A Sportchassis is a spendy item.
You don't need to be "made of money" to get the ultimate tow vehicle...Spend some time on the Escapees HDT forum.
(There's an MDT forum also)
Either way, weight makes all the difference in handling. - ol_Bombero-JCExplorer
2oldman wrote:
If you're made of money get a Freightliner Sportchassis M2 MDT. It's real nice to tow with a truck that weighs 6 tons. If you want control, comfort and safety, the heavier the better. If you mainly want towing power, the new pickups are fine for that.
You don't need to be "made of money" to get the ultimate tow vehicle - with more whistles and bells (and creature comfort) for way less than a new pickup (or a "450").
Will tow *anything* you choose - no special license req'd when registered in (most states) as a MH.
. - Cummins12V98Explorer III
Me Again wrote:
When I drove down and met Larry a couple years ago, I knew right away he was the type of guy that could service his own truck! Chris
Same here! Stopped by on the way back from SoCal. He keeps everything NICE!
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
