- Onerider1150ExplorerThe toy hauler I bought is a pull behind at a 5,600lbs dry weight
- NC_HaulerExplorerWhat is GVW of the 5er you''re wanting to tow...not dry or empty weight, but actual GVW? That is a more realistic weight to use to determine if your truck is capable..Take 20% of 5er's GVW to figure how much pin weight you'll be putting in the bed of your truck..
I'd also want E rated tires on the truck, especially the rear, instead of P rated tires...P rated tires weight rating probably too low for 5er pin weight. - Happy_ProspectoExplorer
Onerider1150 wrote:
I just bought a new to me 27wp Cherokee wolf pack toy hauler and I have a 2015 f150 4x4 5.0, what's your opinion good or bad?
If I was a tow truck driver I would say you made a wise choice.
The information is out there, all you have to do is let it in. - arhayesExplorerHere's the link to the Ford F150 2015 towing guide. It will tell you what THEY say the capacity is. You didn't mention wheelbase and that makes a difference too. Hope this helps.
http://www.ford.com/resources/ford/general/pdf/towingguides/15rv&tt_ford_f150_r2_may19.pdf - Onerider1150ExplorerThat is the one I've bought and I did buy a weight distribution hitch and only hauling a 600lbs motorcycle.
- DirtclodsExplorer IIwhat's your opinion I'm not sure what you looking for as far as an answer. Bitchen rig I'd agree you well not be happy going up hills.
- is_it_friday_yeExplorerI was only able to find your trailer on a site selling a used one. But here is the trailer with the specs Wolf Pack
You may be ok, but you won't be setting any speed records. If I were towing a lot, I would get a 3/4 ton at least. - donn0128Explorer IILikely going to exceed your trucks towing ratings if your planning to carry toys in the garage
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
