Nose High vs Bed Clearance
Rollochrome
Had a Reese Goosebox installed today.
Tell me your opinion here.
Am I too high in the front?
Trailer is 44' long, which makes a difference.
Frame bottom to ground in rear: 22.25"
Frame bottom to ground in front: 26"
Bottom of gooseneck to top of truck bed rail: 9"
Think I am GTG or do I need to drop the Reese down a click?
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
5 REPLIES 5
TXiceman
Go ahead and drop your nose down. 6 or 7 inches is adequate for bed clearance.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
fj12ryder
Ditto to the above.
Howard and Peggy
"Don't Panic"
BB_TX
2โ€ drop should give 7โ€ clearance and get you close to level.
MFL
Nomad II
Nomad II
While you may be good, I'd drop the front a bit more. Nine inches clearance not really needed. Six usually okay, seven is great, most cases.
Jerry
Lwiddis
A picture would help us. Ideally you are level to very slightly nose highโ€ฆvery slightly.
