patnchris's avatar
patnchris
Onboard genset
Thinking about my next trailer and have been contemplating an on board genset. I see that all (except a few toy haulers) have propane genesets. My issue with this is not that I think propane is bad, but that gensets are very thirsty. 30 lb. tanks won't last long and then you are left with looking for a place to fill them. I was wondering if anyone has contemplated using a gas genset with portable tanks, like boats. One could set up a quick connect (like an outboard motor) and when one tank was empty, just connect a secound one and then just go to a regular gas station to fill the empty....any thoughts?
  • I had a Oman that came out of motor home. It had the take out boat tanks. It would run a long time. Bought a Beacon and it has propane gen. To be honest I like the propane.
  • Added a 5500 w genset to a 5th wheel, using boat tanks. Worked well, used extra gas cans to keep the 2 boat tanks full. Use a 2k Honda or Yamaha when travelling more than the big genset.
  • I camp at a military base where we all rotate every two weeks to dry camping.
    ALL RVers use small generators and none use of the rigs use their large genset....
    I would say that a small generator is what I'd prefer
  • I have an onboard Onan 5500 gas. It came from the factory with a built in 10 gallon gas tank. I guess they don't offer this option anymore, but I sure like it. The Onan will operate 15-20 hours on this 10 gallons depending on the load and filling the tank is easy using a battery operated properly rated fuel pump and a portable gasoline can. Works great for me. Talladega here I come in a couple of weeks. I will use approx 20 gallons of gas while there based on previous races.
  • patnchris wrote:
    Not really thinking about A/C. More like 3 hrs or so in the morning for making breakfast and charging batteries, and then 3 or so in the evening. The majority of our dry camping is beach camping on Padre Island. We are usually only there for 4-5 days before moving to an RV park with full hookups. I currently have a Yamaha 2800 I use for this purpose, but am considering a residential fridge and 6 golf cart batteries.
    If there is no A/C involved think solar vs. gas cans
  • patnchris wrote:
    I currently have a Yamaha 2400 I use for this purpose, but am considering a residential fridge and 6 golf cart batteries.
    Are you going to add solar ? If yes, then stick with your Yamaha. It will not get much use except when you want to run the A/C.
  • Not really thinking about A/C. More like 3 hrs or so in the morning for making breakfast and charging batteries, and then 3 or so in the evening. The majority of our dry camping is beach camping on Padre Island. We are usually only there for 4-5 days before moving to an RV park with full hookups. I currently have a Yamaha 2800 I use for this purpose, but am considering a residential fridge and 6 golf cart batteries.
  • I have an on board 5500 Onan LP genset. It works great however I am a convenience user. I do not go off grid often or run genset for extended periods.
    I may do an overnighter here and there but in general I only run the genset for a few hours at a time.
    What you are proposing is a feasible idea. But it really depends on how often you plan to use your genset If you are looking to run genset all day for days at a time. You will need to haul lots of gas to remain off grid.
    I think solar has become a better solution for those looking to remain off grid for extended periods.
    It has been done, but you have to use the proper quick connect. Twin 30s won't last long if you have a 5kw genset running a couple of AC units. Get a spare tank so that you can use 100% of two tanks before refilling. Desert camping you will probably be going to town every couple of days.
