lamopar's avatar
lamopar
Outdoor speakers leaks, 2nd toy hauler same problem
Thought I might drop a note here of a problem I have had on two toy haulers about 6 years apart. The material that attaches the speaker, woofer part of a two way, separates from the foam type material that attaches the speaker to the speaker frame. Our 2011 had it and I never noticed it and did not have a cover for the unit so when it rained it ran in the speaker, down the wall and destroyed the flooring. Yesterday I was playing some music and noticed a scratchy sound on our 2018 unit. When I inspected the speakers I found the foam had disconnected at the bottom from the speaker. It is very hard to see and you must look for a black line where the foam was attached. A slight pull on the foam and you can see it is not connected. I pulled on the top part as well and it is still attached. Probably something you won't notice until you are in the trailer in a heavy down pour but what happens when you are not there is terrible.
