RobWNY's avatar
RobWNY
Pin Box with Air
For those of you that have a pin box with an air bag, do you pressurize after hooking up to the PSI you like and then release the air before unhooking or do you just leave it pumped up to the PSI you like all the time and just check to make sure the pressure is where you want it before you tow again. The reason I ask is because I have a Reese elite airborne Sidewinder that has an air bag. If I try to connect with it pumped up, I can't get the jaws on my B&W Patriot to close tight without some effort. If no pressure in the air bag, it hitches up fine. Being new to having an air bag, I'm not sure when I'm supposed to inflate/deflate the bag. Reese recommends 40 PSI Minimum and 70 PSI Maximum Thanks.
