Jul-17-2022 12:31 PM
Jul-19-2022 07:40 AM
Jul-19-2022 07:00 AM
dougrainer wrote:pianotuna wrote:
Thumbs,
For 50 amps the continuous rating is only 40 (on each leg)
For 30 amps the continous rating is 24 amps.
110 is safe--but low, assuming that is voltage under load. Consider getting an autoformer to correct the voltage.
Mine is set to boost voltage to 124. It cuts in at about 115 volts. No more burned plugs.
I have seen you quote this before. I have 43 years as a RV tech, the FIRST almost 24 years when everything was 30 amp and NO 50 amp RV's. I don't know where you get your mis info. RV electrical systems have their OWN national electrical rating and at no time in my 43 years have I ever hear of the 24 amps for 30 and the 40 amps for 50 amp service. Please post the reference for what you state. RV 30 amp is designed up to 30 amps(3600 watts) of service. 50 amp is for 100 amps(12000 watts). NO DERATING at all. Doug
Jul-18-2022 03:25 PM
Jul-18-2022 03:18 PM
Thumbs wrote:That works. But why have the dogbone?
Oh ok Yeah the fewer connections the better. What I was thinking was to take the male off the Dog bone and replace it with a male twist lock. Take the female off the power cord and replace it with a female twist lock.
Jul-18-2022 03:08 PM
time2roll wrote:Thumbs wrote:Twist lock is fine but nothing off the shelf in the RV world is compatible.
Why not twist or locking connectors? I ask out of ignorance. If I put a male on the dog bone adaptor to the camper and a female on the supply cord I would think that would make a tighter connection rather than just pushing in a friction connection. I realize the limiting factor to the twist or locking connectors. If I put the locking connector on the supply cord and male on the dog bone that would be the only cable I could use unless I replace the other cables in the same manner. What leans me to the locking connectors is the one on the camper is like new and the 50 amp female at that connection is also like new. I was attributing it to a tighter connection because of the locking ability. Idono
Best to have a cord direct from the RV to the pedestal. No adapters. See my amazon link above.
If you go twistlock I recommend Hubbell brand.
Jul-18-2022 02:53 PM
Jul-18-2022 02:28 PM
BB_TX wrote:
If you have quality 30 amp cables and adapters with no poor connections and you are connected to a 30 amp circuit breaker protected receptacle then the connections should not over heat even pulling 30 amps. Even if you have a longer cable. A longer cable can cause a voltage drop, but the current cannot go above the 30 amp breaker, and the supposed cable and adapter rating. And current is what causes overheating, not voltage.
The overheated plug and/or receptacle indicates resistance in one or both of those, either poor contact, poor wiring connections, or possibly cable/adapter not meeting stated rating.
I carried a 25’ 30 amp cable with a 30 amp male plug and a 50 amp female connector for the trailer end (30 to 50 adapter cable) to avoid having to use the dogbone adapter.
Jul-18-2022 02:23 PM
time2roll wrote:Thumbs wrote:I linked the progressive connectors earlier. I believe these are superior.
the question is who makes good connectors|?. I really don't think the Camco connectors are the way to go.
The other question is does it make any sense to put twist on connectors on the female end of the cord and the male end of the pigtail. The male end of the camper 50amp connector is in perfect condition and its a twist on. Maybe that is the way to go.
I would not go twist lock.
Do you have a removable 50 amp cord? If so consider a Marinco removable 30 amp cord that will connect to the 50 amp socket on the RV.
https://www.amazon.com/Marinco-Park-Power-3050PA-25-Male-50A/dp/B07BDYF4HD
Less bulk too when only 30amp is available.
Jul-18-2022 02:12 PM
Jul-18-2022 02:08 PM
Jul-18-2022 01:42 PM
Thumbs wrote:time2roll wrote:
Yes should easily run the fridge and air continuous without issues. A bad battery might run up the power from the converter but you would soon know that.
The connectors are bad.
Yep thats what Im goin with. LOL Anyway, as we progress down this rabbit hole the question is who makes good connectors|?. I really don't think the Camco are the way to go.
Jul-18-2022 01:39 PM
Jul-18-2022 12:20 PM
