โSep-03-2014 04:21 AM
โSep-04-2014 10:41 AM
โSep-03-2014 05:39 AM
Jim is right. We have two 15K units on our 5th wheel and it has never been a problem. I had to change out our front AC unit after I was stopped by the VA state police for being overheight. We replaced the old 13.5 AC unit (with a heat strip) with a 15k low profile carrier heat pump. Good luck.
bigdon68
โSep-03-2014 05:31 AM
โSep-03-2014 05:23 AM
jrp wrote:
with a 50 amp supply, No you wont have to worry about any power management; you can run every electr appliance in the rig at the same time on 50.
Its when you're limited to a 30 amp supply that you'll have limitations, and that's true whether the 2nd ac is 13.5 or 15.
โSep-03-2014 05:10 AM
