Pull Rite Superglide-Maintenance
fivecodys
Good morning guys,
It's maintenance time.
I would like to clean the Way-Tubes on my hitch.
Basically remove all the build up of Slip Plate and re-apply a few new coats.
Anyone done this?
What method did you use?
Thanks in advance for your comments.
Bill
2007 Tundra DC 5.7L V8
SuperGlide 14K
Prodigy Brake Controller
2009 Flagstaff 8528RKSS Ultralight Series
Air Lift 5000
We have enough youth.......... how about a fountain of "smart"? :S
3 REPLIES 3
fivecodys
ford truck guy wrote:
I just did mine.... I take the entire hitch apart , inspect all movint parts, lube moving parts and start on the way tubes... I will sand them using either sand paper or steel wool all the way down to bare metal.. After I do that I look for scratches and or galling and smooth them out.. At that time I re coat the tubes with slip plate. Once dry I re assemble the hitch , re adjust the nylon block and touch up the way tubes with another coat of slip plate as there is always a small scratch in the coverage from sliding them threw the base.Joe
Thanks Joe.
Sounds like a good plan to me. I'm going to do exactly what you did.
Bill
SuperGlide 14K
Air Lift 5000
pcm1959
I have never taken the hitch apart in 2 years. I do keep it liberally coated before and after every trip with Slip Plate and nothing else. I'm starting to worry that maybe I should take it apart for an inspection? Phillip
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
