It's doubtful that your trailer weighs as much as you think. Sounds as if your numbers are the weight of the trailer and the maximum cargo in it. You should visit a set of scales to see where you really stand.
I have a 3/4 ton diesel crew cab, and I limited myself to 11K dry weight and 2K dry kingpin lbs. in a trailer.
All of the Big Country and Big Horn models, except maybe the smallest one, will exceed the capabilities of single rear wheels due to their limited pin weight. Such trailers need a 1 ton dual rear wheel.
