"VIKING" PROPANE CYLINDERS
crickeydog
Has anyone purchased, used, and refilled a "VIKING" propane cylinder? Your thoughts on it's actual use.
Happy camping!!! See y'all down the road!!!:)
USAF RETIRED 02/1992
DOD RETIRED 04/2014
D/W US GOV/DOJ/DEA RETIRED 10/2010
PULL DOG:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT
2004 HOLIDAY RAMBLER PRESIDENTIAL 30' SCD 5'ER
29 REPLIES 29
54suds
I had the tanks that were de-certified ? they were very lite and clear and fit the tank compartments fairly well . I now have two of these which are slightly larger and hard to see the liquid level with out shaking the tank.
I have been questioned about the recall tanks when refilling but never refused . If your worried about being refused you can print out a copy of the propane institute report to show these tanks are and store it in your propane compartment.
2021 Chev 6.6 duramax ltz DBL cab,drw,4x/torklift tdn's,
1999 Bigfoot 1011
rider997
fj12ryder wrote:
Me Again wrote:
Right or wrong, more and more propane dealers are refusing to refill them. Chris
Do you know that for sure, or are you speaking of one local filler? And are they refusing because they think they are the ones that originally failed? IOW are they mistakenly refusing to fill them?
I don't have any, but I like the concept of being able to know how full the cylinders are.
The cylinders come with DOT certfication paperwork. I have not found any fillers who refused to fill the cylinders after being presented with the certification paperwork. Certainly there may be some who won't fill them, but it's likely to be out of ignorance or conflating the recall on old bonded cylinders (made by Lite Cylinders) with the safety of all composite cylinders.
rider997
ralphnjoann wrote:
Do the Vikings have to be recertified? If so, how do they stamp them?
The cylinders are stamped with a statement indicating they should be recertified every 5 years. In some jurisdictions they only need to be recertified decadally.
fj12ryder
Howard and Peggy
"Don't Panic"
Me_Again
avvidclif1
I was considering them but found out the height limited me to 22 lb cylinders and I didn't want to lose 16 lbs of capacity.
Clif & Millie
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2015 Heartland Cyclone HD CY3418 Toy Hauler
ralphnjoann
rider997
Here's an older thread on Viking composite propane cylinders...
I own them and I love them. Very light and well made. Hexagon Ragasco (the Norway based parent company) products were never part of the DOT recall on composite cylinders. The cylinders weigh substantially less than even aluminum cylinders, and are about half the weight of a steel cylinder (a 17lb Viking cylinder weighs 10 lbs; a 20lb Manchester Tank aluminum cylinder weighs 17 lbs). I'd recommend them any day...
I converted from dual 30lb steel cylinders to dual 20lb composite cylinders and saved over 60lbs of weight from well behind the rear axle of my truck. It's one of the cheapest ways to drop that much weight that I can think of.
FlatBroke
crickeydog wrote:
fj12ryder wrote:
What? You expected only people who own the things to respond? Fat chance.
Yea I know. You'da thought by now after all these years I'da known better. But like anything else, ya kinda figure, "Ok, one last time I'll ask a question in hopes of a knowledgeable answer". Fifteen responses so far and not one legitimate answer. "DA" me. Lesson finally learned!!!:R No more questions!!!
Sorry, you asked if anyone purchased one. The answer mostly was no. Seems question was answered.
Hitch Hiker
"08" 29.5 FKTG LS
lylejiggs
I have the 11# cylinder for my Weber grill. Expensive...yes, Doesn't rust...yes, safer than a steel cylinder...they don't explode they melt down. Lighter...yes noticeably lighter empty.
I tried to purchase the 31# cylinders this year and was told by Viking they don't make the 31# any longer due to low demand. They make the 22# for the front of travel trailers but I have 30# steel in my FW.
It was worth the price to me for the 2 year warranty, non-corrosive, lighter and safer. My Viking will likely outlast my two steel 30# tanks on the FW.
2015 Ford F-350 SuperDuty SuperCrew 172WB PSD
2015 Grand Design Solitude 369RL
Andersen Aluminum Ultimate 5th Wheel Connection
waltbennett
Got one of these last year: http://www.amazon.com/gp/product/B00EUG1DCE?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
For $35 delivered, it beats getting a see-through tank any day!
'06 F350 TD, Softopper, airbags, AeroShield, coolant filter
'10 3665RE Hickory edition, wetbolts, Firestone LTs, Trimetric Battery Monitor, 4x100w panels & Morningstar TS-45, still tweeking.
fj12ryder
OTOH it would appear that they aren't all that popular for some reason. Maybe the price point is just too high, or people don't trust them after the problems with the early composite tanks. Ya never know until you ask.
Howard and Peggy
"Don't Panic"
crickeydog
DOD RETIRED 04/2014
PULL DOG:
FlatBroke
When I bought my Lite Cylinders they were only $110 for two. Got them from a farmer friend that was a cousin of the owner. He even filled them from his farm tank. That was about 11 years ago so guess I wasn't hurt too bad. Really going to miss e'm.
Hitch Hiker
"08" 29.5 FKTG LS
