Mr__Coach's avatar
Mr__Coach
Raptor Black waste tank not draining
OK, so I just bought this raptor in AZ. Pulled it up here to the cold north, and yes it's been a horrible april up here.. So, now I found out the black water tank is not draining.. I have all the valves open, I have 3 valves and they are all open and have been since I purchased it. I've poured water down the sink and toilet. Water comes out of the sewer drain when putting the water down the sink but nothing comes out of the black tank.. Today I poured 10 gallons of hot water down the toilet hoping that maybe it would melt any ice build up that may be down there from our cold weather.. Nothing happened, even tried running a snake up the sewer pipe but I think it took a different path instead of going through the black water tank, I put about 20' through before I decided to pull it out. So now what can I do? Try to back flush it?, can't seem to get the valves shut either, they are all stuck in the open position. I don't know if these valves are the ones with the cables to them or not, can't see anything underneath with the insulation and enclosure under it. Anyone have any thoughts what might be happening? What else can I do to flush this system out?????
