mcrosa wrote:
I will be retiring soon and want to go wandering with the wife. Am looking at 5th wheels but want something under 30 feet ideally 20 to 25ft. Any suggestions? I have been looking but all I seem to find are very large. Thanks in advance for your help.
Mike C
We're on the same quest. So far have looked at the Jayco HT line, Rockwood Light, and Open Range Light. VERY hard to find something under thirty. (Hint - for Jayco, add 4' to the name to get the approx. length, so 26.5RLS = 30 1/2 ft, etc.) The named length is roughly what will actually be sticking out behind your truck when towing.
We found the few 26-28 footers were just too small. 30 ft. seems to work really well for two people for longer trips (1 mo. plus). Going bigger than 30-34 and you have more challenges finding campsites in state/national parks. Sometimes even 30 is a bit big-ish.
If you are going to stay under the 34 ft mark, generally a truck with a payload of about 3,000 should be more than enough. That's the big number to worry about, not "how much can it pull". Don't be fooled by "Half Ton Towable". We have a Ford 1/2 ton with all the tricked out towing and payload options - and it is extremely hard to find fifths that have a pin weight light enough. The newest F-150's give more margin, but you are probably better serviced looking in the F-250 class (or equivalent in other brands).
