abc40kids
Sep 09, 2016Explorer
refer question??
I have a Dometic model #RM1350SL side by side mounted in the slide. My fifth wheel is a 2015 and the frig works, just not as cool as I feel it should be. From the factory it has 4 small fans that are mounted right under the coils in the upper compartment controlled by a thermostat. I was thinking about mounting a fan in the lower compartment by I'm limited on room. I can mount it so it blows straight out the vent or straight in the compartment?? no room to turn it to blow on any component.
My question is, should I have the air blowing in or out of the vented cover? Thanks, Jeff
Also have two battery powered little fans inside the frig, seems to help a little, noticed a little ice starting to attach to the fins this morning after adding the second fan inside.
