TenOC wrote:
shadows4 wrote:
H
Got under the trailer today and the new axle is 1/2 inch narrower than the original.
Diameter or length????
Might want to think about that question;
You can see it on the drivers side. The curb side is lined up like it should be. Is this going to be a problem down the road? Thanks.
First, it is normal for axles to walk side to each as you turn. I would think if you stopped to check while going in straight line both axles should be centered. This would worry me. And I would not be satisfied if I paid for new axle installed and did not match.
